Ball Joint
How hard or easy is it to replace a ball joint? I was riding on pavement the other day
and my wheel about came off...that sucked. Anyhow anybody know how much $$$ ?
[img]i/expressions/face-icon-small-frown.gif[/img]
Later
Later
It's very easy to do. And the ball joint cost about 32 bucks.
Jack up your bike, remove the tire and shock, unbolt the ball joint from the knuckle/spindle, remove the Cir-clip from the bottom side of the a-arm that holds the ball-joint on, use a SMALL wheel puller to press the balljoint threw the a-arm hole.
Then to install it just bolt it to the knuckle/spindle, put some Green lock tight around the ball joint, slip it in the a-arm, put the cir-clip on, put the shock on, then put your tire back on.
Simple as that.
Simple as that.
