Does anyone have the procedure for checking valve clearance ?
Eh' the procedure is really very simple, remove everything nessessary to gain access to the cylynder head cover, remove the cover, set the crankshaft at TDC on the compression stroke. Measure and adjust the valves. This is ussually done with the engine cold. Some one may be able to provide the exact spec's for clearance on that motor, but in a pinchjust set them for .005"
