New Battery and Battery vent tube?
Old Sep 25, 2001 | 12:18 PM
gspman's Avatar
I need to get a new battery and in reading the manual, it talks about the vent tube being very important. Is this tube for draining the battery or the battery housing? Why would the battery need to drain?
In regards to a new battery, can a different brand of battery be used in a 2000 500 auto?
Anyone else replaced a battery in less than two years?
Thanks for any replies!
Old Sep 25, 2001 | 01:16 PM
minehunter's Avatar
The vent tube is to disperse the hydrogen gas that is created when the battery is being charged and also to let any excess acid drain and not come into contact with the frame and causing corrosion.
Due to the battery size they will go bad if they are exposed to freezing temps for extended periods of time. Also the rough riding will affect them because rough riding caused the sediment to slosh around and will sometimes short out the plates.
Old Sep 25, 2001 | 03:22 PM
gspman's Avatar
minehunter, thanks for the quick response!
Do all ATV batteries come with the drain connector for the drain tube, or do I have to buy an Arctic-Cat specific battery?
Old Sep 25, 2001 | 04:48 PM
minehunter's Avatar
Every M/C and ATV battery I have ever seen all have vent nipples on them. If it will fit in the space provided and the polarity is observed, it should work just fine. Good Luck.
Old Sep 26, 2001 | 12:58 PM
gspman's Avatar
I got new a battery from AutoZone last night. The old one was dead. The new battery is about a quarter inch taller than the old one, but with a little bending of the battery bracket, it fits nicely. The dealer wanted $60 for a battery, the one I got was $29. I can handle a bent bracket for half the price!
bzdok1234
30
Feb 23, 2016 01:55 PM
Hunter100us
Oct 7, 2015 11:46 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
