An old debate...the oil issue
Old Dec 4, 2001 | 05:01 AM
  #21
Elrancho's Avatar
They are most interesting, You'd swear from the way some folks avoid the synthetics they glowed in the dark, or maybe they're secretly smuglled into the US to make our motors die...
( BTW: the tempereture was at 58 degrees this evening, I had an issue where I needed high idle (about 2300rpm) to run some power equipment...for about an hour, the thing [trx350fe-aircooled] doesn't even get hot with the mobil 1 in there, the fan never came on( yes the fan works fine, but you have to work the thing to get it warm ), there's that little friction present in the motor running that stuff.
Old Dec 4, 2001 | 01:12 PM
  #22
boxofrokx's Avatar
Read your owners manual. It will tell you the grades and ratings of oil you can use. Very smart and well educated people told you what to use. No one on this board knows as much about oils and how they affect your quad than these people with phd after there names.
There are syn. and dino oils that meet these requirements, either will work fine.
Mantainence is the most important issue. Do the oil change at the proper intervals and the motor should outlast you. Neglect the motor (even with Amsoil in it) and you will make an anchor.
I do know I am not comfortable with oil salesmen (Amsoil) coming on these forums touting there product as 'the best made' or 'nothing better' ect. and next saying 'buy it from me here'. When you ask for proof of their claim, they bash you as being an ignorant a$$hole. SHOW ME SOME PROOF.
Charlie
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
