Pulling out front axles?
Old Jan 23, 2002 | 03:12 PM
GerrBear's Avatar
Assuming you've disconnected the A-arms & tie rods, would you be able to pop out the axles from the differential on a 2001 AC500? Will it take a good hard tug to pop 'em out or does it require any special tools? I'd hate for the drive shaft to pop out of the CV joint rather than from the diff when giving it a hard pull. It's probably similar to servicing a front wheel drive car, but I never had a front wheel drive car to work on!
Thanks in advance!
Old Jan 23, 2002 | 05:04 PM
mudcat47537's Avatar
Just push the axle in and then give it a good swift pull, it should pop right out. Just the reverse going back together. Good luck.
Old Jan 23, 2002 | 11:35 PM
racnooc's Avatar
on my 500 front cv joint i have a big snap ring in it to keep the cv joint from separating. when you take the boot off look closly inside and you should be able to see the snap ring. also if you have some rubber gloves i would recomend wearing them the grease that is in the cv joint is a pain to get off your hands.
Old Jan 24, 2002 | 11:28 AM
GerrBear's Avatar
Thanks guys... I just wasn't sure and wouldn't want to break anything! [img]i/expressions/face-icon-small-confused.gif[/img]
bzdok1234
30
Feb 23, 2016 01:55 PM
Mphillips
Jul 2, 2015 07:20 PM
Rooky
10
Jun 23, 2015 09:35 PM
mitchetr
Technical and How-To Articles
Jun 10, 2015 08:36 AM
WilliamBos
Jun 9, 2015 08:18 PM
