Brake Light
Old Aug 30, 2002 | 11:00 AM
cat300's Avatar
I have a 2001 AC 300 4X4, the brake light comes on when you apply the foot brake but does not come on with the hand brake. Any suggestions on how to fix it?
Old Aug 30, 2002 | 05:05 PM
redneck76's Avatar
On the hand brake there is a small plastic cylinder with a plunger? that releases out when you squeeze the brake lever. Check to see if it is moving freely. The wire that comes out of that cylinder has a plug on it about a foot down. Check to see if it is unpluged.
Old Sep 2, 2002 | 09:41 PM
chunkyboy's Avatar
do what he said ,if not a fix ,then remove the gas tank , look in front of the steering neck ,trace the wire down the neck , to where it is pugged in ,they pull them selfs apart here , cat has started wire tieing them together in 2002 ,my 400 is , my 200 250 did this to ,check this , if its the problem just reconnect and wire tie it , hope this helps .
Old Sep 2, 2002 | 10:10 PM
cat300's Avatar
Thanks for the help, I will try both repair tips. Im having the same gear indicator problem that a lot of other people are talking about so I might as well check all the wiring. Other than these two minor problems the Cat has been great.
Old Sep 3, 2002 | 11:58 PM
redneck76's Avatar
I would take the front rack and plastic off. Doesnt take that long and its much easier to work.
Cummins Driver
Sep 11, 2019 01:22 PM
sweaver
11
Aug 18, 2015 03:47 PM
DeFox500
Jul 26, 2015 06:32 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
