How deep?
Old Mar 26, 2000 | 08:05 PM
JKB's Avatar
JKB
AC400 4x4
I have noticed the last couple of times that I been riding that when the water gets deep the fan blades start hitting the water and making a splashing noise. Has anyone got some experiance in deep water. My concern is that the electric fan motor will short and burn out.Or overload due the resistance created by the water.
Regards Jim
Old Mar 26, 2000 | 11:33 PM
aczr2k's Avatar
It will blow the fuse before it burns out the motor. I have had it happen before and now I carry extra fuses along.
Old Mar 28, 2000 | 11:30 PM
maxout's Avatar
water?
hell yeah!
sunk it so bad not even funny!
but anyway honda's a susuki's go best in water proven fact.......
well i do'nt know about artic's cause no one sells them here but i would think if it is a good 4wheeler they would have noticed the problem and it wouldn't happen
Old Mar 28, 2000 | 11:35 PM
Jpmn's Avatar
Hey i have a 300 fourtrax and i've been through water over the bars and it still runs great.
Old Mar 29, 2000 | 02:30 AM
BONER's Avatar
I had my 99 model rewired like the 2000 model so I could have the fan on all the time. What I did is install a switch that allows me to turn the fan off for deep water.
Old Mar 30, 2000 | 11:39 PM
tinmandown's Avatar
2000 300 4x4, water eventually gets in, not much you can do there. but i sugest a silicone spray. i soak my AC regularly, my kids to. so far i've been lucky, but luck or not, its worth it.
Old Apr 1, 2000 | 05:08 PM
AC4004X's Avatar
I have a 99 400 4X and have been through a lot of water with my machine. I haven't had any problems with the fan, but I find that the stupid headlights and the taillight aren't water proof and fill up with water. If the water splashes on the bulb when it is on it will burn out.
Old Apr 5, 2000 | 08:22 PM
vtCatamount's Avatar
Last week end I was in water nearly up to the seat. Well-not so much water, more like a thin soupy mud with lots of grass, weeds and the like mixed in. I was with 8 other machines and when every one made it through this 100 yard long hole, I noticed my fan wasn't running. I reached up into the fan area and removed a big clump of grass, mud, and other debris. The fan spun freely by hand but still didn't run when I turned on the key. I checked the fuse, sure enough, fuse was blown. Swapped out the fuse with the accessory fuse (both 15 amp) and problem was solved. Now I carry spare fuses and and thinking of installing a switch to stop the fan before I get into anymore of natures deep, mixed gumbo, soup. I see posted here someone already did that, great idea.
Old Apr 7, 2000 | 11:35 AM
thomas's Avatar
maxout you are right i have a suzuki 230 quadsport. i sunk it over the light in water. it stalled and all but it took about 10 kicks and it started right back up no water in the oil or nothing didn't even do to my engine just my pipe filled up i was amazed.
Customer Service #1
May 15, 2020 08:46 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
switzomatic
Aug 24, 2015 12:57 PM
