Shifter Linkage Woes
Old Feb 19, 2003 | 01:29 PM
Cancat's Avatar
Default Shifter Linkage Woes
Just an FYI to all you Cat owners:
If you own a pre 2002 250 or 300 it has a Cable shifter linkage. Mine stretched and jammed the transmission between gears, and almost trashed the engine, because the engine and tranny are all one oil reservoir on a 250 or 300. I had it at the Cat mechanic for three weeks, they got it unjammed, but couldn't figure out what was wrong, so they just sent it home. I got it home and couldn't even get it off the truck, because it wouldn't shift. Brilliant service guys in Peterborough eh? I found the problem, and had to wait another two weeks for a new $160 cable to fix the problem.
If this ever happens to you do not buy a Cable for your year of ATV!!! Make the dealer order you a Linkage of a 2002 or newer...it is not a cable, it is a solid linkage...cheaper...and much better design. I only wish I had found this out before I replaced my cable.
PS...If you are from Ontario, never ever take your ATV to Korpi's in Peterborough!!!!!
Old Feb 19, 2003 | 09:14 PM
Arctic330's Avatar
will the new linkage bolt right on to say a 1998 300
if so do you know how much they run??
thanks for the tip.
Old Feb 20, 2003 | 10:20 AM
Cancat's Avatar
Yes it is a bolt on, no mod installation, not sure of an exact price, but it is less that $160 canadian and installs in 20 minutes.
Old Feb 20, 2003 | 11:13 AM
racnooc's Avatar
my 300 has been shifting kinda weird lately and i was wondering if the cable needed adjusted or something. but the soild linkage sounds better so i will try and install that. that is good information thanks for shareing.
Old Feb 20, 2003 | 11:52 AM
RotaryRocket's Avatar
Thanks for the info Cancat.
There are no dealers around me, so I need to order it on line. Would you happen to know what part numbers I need to order?
Thank you.
Old Feb 20, 2003 | 02:54 PM
DirtDoc's Avatar
RotaryDude,
You have a dealer in Tracy (Travl'n Toys, ph 209-833-9111). Or order from www.brownsleisureworld.com, I get stuff from them all the time. Takes about two weeks (from Canada).
Doc
Old Feb 20, 2003 | 02:58 PM
Thanks Doc,
I have not tried the folks in Tracy, how are they? Are they knowledgable?
I tried to get a hold of a dealer in Suison city (supposed to be closer to me!), they were totally clueless.... they kept on saying they have things on order for me and it would arrive in a couple of weeks. I think it has been 4 months now!!! I have given up on them.
Old Mar 2, 2003 | 12:44 AM
Volvoman's Avatar
I did this to my 01 300 4x4. I replaced the foot shifter,#0502-253, linkage#0502-256 and bushing#0432-091. I think this cost me about 65.00 US. It shifts somwhat better but my cable had not gone bad yet. I may do this to my wifes 300 also.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
salixair
Nov 3, 2015 08:25 AM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
