Learning from experience
Old Apr 9, 2003 | 10:47 PM
CatKrazy's Avatar
Default Learning from experience
http://www.alpha-sports.com/parts/at...SEASSEMBLY.htm
go there. There is your rear ring gear!!! #5 Caution this is for the AUTO! Not the Manual
Old Apr 10, 2003 | 01:48 AM
maximus's Avatar
the part number that is needed is 0402-965 it cost 117.00 it is for a manual 500i. it has 36 teeth and the auto has 34 teeth. the manual is geared lower than the auto how about that. the microfish does not show the manual yet but it does show the 500 tbx which uses the same rear diff. i called my dearler and the part number above is what he said was for the manual.
Old Apr 10, 2003 | 01:50 AM
maximus's Avatar
oh yea the front and rear cvs call for the same part number and all the bearing and shims and seals use the same part number front to rear. the only thing that does not have the same number is the housing covers are both different. after looking at both picts i think it will work.
Old Apr 10, 2003 | 09:45 AM
CatKrazy's Avatar
The most important part on the whole deal is the hoiusing itself.. The rear sub cannot be any wider or any thinner than the one up front or you will have to reshim! to make up the difference.
Old Apr 10, 2003 | 01:53 PM
  #15
Vforcer's Avatar
seems like a locked front diff would make it hard to steer ??
this must mean the the limited slip doesn't lock up tight enough ??
Customer Service #1
May 15, 2020 08:46 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Levi Enstad
Sep 26, 2015 05:36 PM
cboler9
Sep 24, 2015 08:35 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
