What happens when you neglect your winch?
Old Apr 9, 2003 | 08:30 PM
voodoo's Avatar
Default What happens when you neglect your winch?
This, this and this.
Dont neglect your poor winch!
Old Apr 9, 2003 | 11:59 PM
Fango's Avatar
Not pretty at all vewdew!![img]i/expressions/face-icon-small-frown.gif[/img]
Old Apr 10, 2003 | 09:47 AM
CatKrazy's Avatar
How did you allow this to happen
Old Apr 10, 2003 | 10:06 AM
voodoo's Avatar
I neglected regular maintenance. IE: In mud, use winch, get home, not unspooling and cleaning then respooling. I did not do this on a reg basis. Let this be a lesson to me, and all you who do not inspect and clean winch after every use.
Old Apr 10, 2003 | 11:07 AM
tricat's Avatar
I run a V plow in the winter and it messes up the cable pretty bad so I change it after the snow season. I also put a connector on the wires so its easy to remove. 4 bolts and unplug the wires. Makes it easy and the cable is only 30 bucks.
Old Apr 10, 2003 | 08:38 PM
longlake's Avatar
What are you supposed to do to maintain a winch besides cleaning the mud etc.?
Also, has anyone ever took apart their winch switch. I have the one with a handle that you twist to engage. It is not fully disengaging, feels like a spring inside may be stuck or broken. Any tips would be appreciated.
Old Apr 10, 2003 | 09:12 PM
CatKrazy's Avatar
What kind of connector did you put on your winch, to beable to remove it easily
Old Apr 10, 2003 | 11:19 PM
voodoo's Avatar
longlake: ill be stripping the rotary switch and the winch. Ill post pics. But if you do a search there is a pictorial of a warn 2000lb rebuild. I cant remember where i saw it now.
CK: Removed from the quad you mean? 4 Bolts is all it is.
Old Apr 10, 2003 | 11:24 PM
CatKrazy's Avatar
no I mean electrical wise. I thought you said you added connectors of some sort to make it easier to remove from the electrical connectors
Old Apr 10, 2003 | 11:26 PM
voodoo's Avatar
Naa, nothing like that, just the 2 connectors that were already on there. Just a quick spin of the ratchet and they are off.
