help on 250 Artic Cat
Old May 10, 2003 | 08:06 PM
Machster22's Avatar
Default help on 250 Artic Cat
Hey, my cousin just got a Artic Cat 250, 2003 manuel trans. and he will drive it and i would die on him and he can't get it to shift down into neutral to startit again without pushing it backwards. Does anyone know a solution to this so that it won't die neither will it lock up in 1st gear cause this never has happened to me on my ATV. Thanks
Old May 10, 2003 | 09:05 PM
Machster22's Avatar
Does anyone know what I would need to do to it or what the problem could be.
-Mike
Old May 12, 2003 | 11:49 AM
memento's Avatar
I had trouble shifting once on my 2003 250. Turned out it was a loose locking nut at the end of the metal rod that goes from the tranny to the shifter. Don't know about the stalling.
Old May 12, 2003 | 04:55 PM
tricat's Avatar
Stalling could be a number of things. Does it idle properly after it warms up? Does it stall when riding or does it stall when he is stopped? Need more info.
I would check the linkage rod and make sure everything is tight. Also sometimes when you stop there is still presser against the gears so you have to rock it a bit to get it out of gear.
If you still have warranty...Take it in.
Old May 12, 2003 | 08:52 PM
Machster22's Avatar
Well it it stalls when he stops sometimes or like if he is about to go up a tiny hill that a 90cc could probably make and I know it's not that sorry. And when it gets stuck in first gear is usually when it stalls and sometimes right before he puts it in reverse. Thanks alot for your help.
-Mike
Old May 15, 2003 | 09:34 AM
tricat's Avatar
I had to adjust the idle several times to get it right on my daughters 250. It also kept cutting out. It gets better and better as it gets more mileage on it. Bought it in December of 2002 so it only has about 150 miles on it so far. It is very cold blooded compared to the other cats we have, not sure if its the temperment of the 250 or if it will get better after breakin? Guess I will wait and see.
Old May 15, 2003 | 10:56 AM
jbird's Avatar
I rejetted my 250 because of cold-blooodedness.My dealer said it was a common problem.They did it under warranty>helped alot.Ask your dealer.
Old May 15, 2003 | 01:56 PM
tricat's Avatar
Hey thanks jbird !! I'll be sure to get it in cuse the warrenty is done next month.
MikeyBoyesq
Nov 27, 2020 02:44 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
Jbird4681
Jun 9, 2015 01:59 AM
Kagey
Feb 25, 2002 01:56 AM
