2003 400 AC ITP Tire upgrade size choice?
Thought I put this out. With all the talk about broken axles I am alittle leary of throwing a set of 27inch ITP 589s on my AC 400. I am thinking of a set of 25 inch ITP 589s to replace the stock tires. Has anyone done that? How have they found it? Worth the money?
I ride mostly snow or in the fall hunting in mossy/looge gravel underneigth stuff. Not a ton of mud, fairly dry here. Stock tire would probably work good here but the extra bite would be nice because I'm often going where there is no trail and through willow patches and need extra grip.
Might be a dumb question but just so I dont order the wrong tires, the stock 400 tires are 25 x 8-12 front and 25 x 11 - 12 back. That means the rim diameter is 12 inches on both, the outside tire diameter is 25 and the tire width is 8 and 11 respectively? Correct?
So if I go with 26X9- 12 or 25x10-12on the front and 26x12-12 on the back I should be okay for my stock rims?
