'86 ATC 250R - Changing Rear Disc Pads, Help!
Old Jul 2, 2003 | 05:15 PM
waynerod's Avatar
Default '86 ATC 250R - Changing Rear Disc Pads, Help!
I had a similar problem with the bleeding - I found that not letting the pedal come all of the way up while bleeding solved it.
Hold down pedal - loosen bleeder valve (into a tube going into a cup of fluid) - let fluid escape - tighten bleeder valve - pump 3-5 times letting the pedal only come half way up - repeat.
These old brakes are a pain, I'll give you that. They work great until you touch them.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
merryman
Jan 19, 2016 04:29 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
CRamshaw777
Jul 18, 2015 05:46 PM
