Oil Change
Old 06-07-2000, 11:34 PM
Dingo's Avatar
I have a couple of quick questions. I picked up a 1980 Honda ATC110 recently and wanted to do some routine maintenance. I went to change the oil and found 2 drain plugs under the machine (at least they both appeared to be drain plugs). I found the plug for the crankcase but what is the other plug for?
I assumed it was for the transmission, but behind the plug was another plug that needed to be removed with a phillips head screwdriver. Behind that was a couple of springs and no oil.
What did I remove and what could I have done wrong if I just put everything back the way I found it?
If this second plug is not the transmission drain, is there one and how do you change the oil in the tranny?
Old 06-08-2000, 10:02 AM
retro's Avatar
The best thing to do is get a Clymer manual. They are about $25-$30 and are very usefull. Usually the transmission and crank case use the same oil.
ERIC
ReconBayou
10-31-2022 05:37 PM
ultangler
09-05-2021 08:06 PM
Jackg17
Ask the Editor
07-16-2018 04:01 AM
Gwolf228
02-18-2017 01:36 AM
Jackg17
09-26-2015 09:30 PM
Quick Reply: Oil Change
