84 250r pros and cons
Old Oct 25, 2003 | 09:24 PM
zillasrock's Avatar
Default 84 250r pros and cons
i thought a 81 only had 5 speeds? my 84 only has 5. is that right?
Old Oct 25, 2003 | 10:15 PM
atc86r's Avatar
It only had 5. He probably assumed it was sixth. They need six. Or bigger front sprocket.
Old Oct 27, 2003 | 06:48 PM
dragracer789's Avatar
smok3d- your friends 250r dosent run right because it was jetted for a 295 cylinder. so shes ganna be a bit on the rich side untill you rejet it.
*** by the way guys you can get a 295 sleeve for 160 (about) and drop it into a 250 jug. so it would be a 295. (no need to buy another cylinder.)***
Old Oct 29, 2003 | 02:28 PM
jaycekarl10's Avatar
Zilla, your Bronze or "National" DG exhaust is about the only one available for those years so you're good there. Yeah, I forgot, the original 300 kits or "red heads" actually were a complete head, jug, piston etc. and was quite expensive. The 295 kit may be worth looking into. I had also had the top end and cylinder blasted and anodized to help heat dissipation and good looks of course. I miss the ol girl.
Old Oct 29, 2003 | 05:00 PM
  #15
zillasrock's Avatar
were do you find a 295 kit?
Old Oct 29, 2003 | 05:10 PM
  #16
la sleeve
Old Oct 29, 2003 | 06:40 PM
  #17
zillasrock's Avatar
how about a 300 or 295 piston? any suggestions?
Old Nov 2, 2003 | 12:59 PM
  #18
whiteman350x's Avatar
Wiseco will still make pistons for the old 300 kits and they make over bores also. The draw back is you have to order at least 4. Here is a link to a guy on 3ww (he also used to come on here) that was looking for someone to go in w/ him and buy some. http://www.3wheelerworldforums.com/v...ic.php?t=13588
Old Nov 2, 2003 | 08:51 PM
  #19
chipdog4's Avatar
Another Pro for air cooled is that you can rebuild the top end in under an hour. Mine rings took a dump and I had the cylinder off in 15 minutes. If I would have known it was just the rings and pistons, I would have ordered them and had it rebuilt in 45 minutes total. But I need to now order rings and piston.
Andy
Old Nov 2, 2003 | 10:08 PM
  #20
zillasrock's Avatar
whats the top speed of a aircooled? anyone know?
