honda 200s
Old Nov 23, 2003 | 11:18 AM
ALABAMA200s's Avatar
Default honda 200s
ok i have accepted the fact that i can live with this tug of war..........now on to the engine rebuild.....she makes a lil smoke and only wants to run at half choke ......any thing i should check first?
Old Nov 23, 2003 | 11:40 AM
AtcRida's Avatar
Default honda 200s
are u letting it stay on choke for a lil bit? It happpens to me if i dont let it stay on choke for a lil bit then i cant run it ,and the decompression cable u dont need it i never use it i just pull and i starts right up.
Old Nov 23, 2003 | 01:57 PM
Default honda 200s
yep i let it stay choked for a good while and then as soon as i turn choke off the engine dies
Old Nov 23, 2003 | 03:25 PM
AtcRida's Avatar
Default honda 200s
check the jets u might need more gas u have to much air and not enough gas going in the carb its easy i did it like 3 weeks ago to mine that should fix ur problem
Edit : Did it turn off after a while of being chocked?
Old Nov 26, 2003 | 08:09 AM
  #15
jack13's Avatar
Default honda 200s
Your ignition timing probably needs to be readjusted.This is typical if the spark fires too early before top dead center.This is accessed under the little cap on the top left hand side of the motor.good luck
Old Nov 27, 2003 | 08:29 AM
  #16
jack13's Avatar
Default honda 200s
When I referred to your timing it sounds like its too far advanced in the cycle hence the cord getting jerked out of your hand when the piston gets forced back down on its way up.This also explains why its running poorly.Try retarding the spark by adjusting the plate under that cap where your pickup coil is and before this check the integrity of the little fly weights and springs.This is the spark advace they could be stuck or a spring broke.Good luck
scman843
Jun 18, 2017 10:21 PM
theddaug
Aug 15, 2015 09:17 AM
95wolv
Jul 17, 2015 08:13 PM
timster911
Jul 13, 2015 01:57 PM
