What size bolt pattern is my hub?
Someone changed the hubs!
I measured it @ 4.5" and this chart shows it to be 114 which I assume is a 110 or 115 bolt pattern?
http://www.hawkmicro.com/convert/Convert_HawkMicro.htm
If it is for that 82 R, it should be 4/130 stock. It very well could be 4/115 (banshee, blaster, warrior, raptor) pattern if the axle spline is the same as a 200x, which I think it is. The 200x uses the same spline as yamahas, so using 200x hubs is the easy way to put 250r pattern 4/110 on a banshee.
blueandy88
08-30-2015 08:26 PM
