I need some advice (broken bolt)
Old Mar 16, 2004 | 11:35 AM
Madwolverine's Avatar
Default I need some advice (broken bolt)
ThrashAndCrashUntilItsTrash is right about heating the bolt. I was just being lazy in my first post and assuming that you were not skilled with a torch. The heat could break the bolt loose by first expanding the bolt and then cooling and shrinking back to its original size. As thrash stated just work the bolt back and forth while heating and it will probably come out. I do suggest trying other options before using heat. And be sure to use the heat sparingly.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 16, 2004 | 03:02 PM
XDAWG's Avatar
Thanks for all the tips guys I really appreciate it!
XDAWG
bvolks
Sep 13, 2015 12:57 PM
David Diaz
Sep 8, 2015 04:44 PM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
