gear ratios
Old May 9, 2004 | 01:44 AM
pondrunner's Avatar
Default gear ratios
what is the stock gear for an 84 200s. And what could I put in it to give it a better top speed and keep the 1 and 2 gear low.it will hit any where from 50 to 60 mph. I was wondering If I could change something to make it hit about 70. and keep the first two gears low to get up hills and play in the mud and other fun stuff like that.
Old May 10, 2004 | 02:38 AM
ThrashAndCrash's Avatar
Default gear ratios
I think you had a 43/11 stock ratio. Keep the 11 and try to get around a 40 rear sprocket. I am running a 40/12 in a 200X and I hit around the low 60's but low end torque and speed is right on![img]i/expressions/face-icon-small-happy.gif[/img] Throgh an aftermarket exaust (or gut yours) on it to help it out too.
Old May 10, 2004 | 09:08 PM
pondrunner's Avatar
Default gear ratios
so this will give me a good low end torque and give me a higher top spedd as well. That what I was looking for, for it.
Old May 10, 2004 | 10:31 PM
pondrunner's Avatar
Default gear ratios
I was looking in a magazine and I can get a sprocket for $15. Is this a good deal. I was thinking of put another one on it. I guess i'm trying to turn my 200s into a 200x. but would be the difference between a 47 and 40 tooth sprocket.
Old May 11, 2004 | 03:22 AM
Default gear ratios
$15 dollars for a rear sprocket is a good deal but expect to replace it in a year, the higher you spend now the loger it will last(for the most part). But I use the cheap sprocket and a cheap chain, then I will just buy another cheap one in a year when they go out![img]i/expressions/face-icon-small-happy.gif[/img] If you change your rear sprocket to a 47 then you will pop a wheeley no prob, but you will loose at least 5mph on your top end. You will smoke them on a short race, but the longer the race the more you will get left behind. By changing the sprockets you will either get faster at the begining or at the end, you can not have both.
Old May 11, 2004 | 07:53 PM
pondrunner's Avatar
Default gear ratios
ok that sounds pretty good. What would happen if I put a 38 on. and do i have to replace the chain every time i change the sprocket. And do you know what size sprocket a 85 110.
Old May 12, 2004 | 12:39 PM
Default gear ratios
I think the 11/38 would be an interesting combo to try. You will notice a good difference. By the way, that is the advantage of buying the cheap sprockets, play with the gearing, if you find the perfect one then you could buy a good set. I would hate to spend $60 on a rear sprocket and decide I hate the gearing[img]i/expressions/face-icon-small-happy.gif[/img]
The only prob you might have with the 38 is your take-off, That will depend on your clutch, weight, engine H.P., and YOU! If you find yourself frying the clutch durring take-offs, then it is too high of gearing (I dought you will have this prob)
Old May 12, 2004 | 10:04 PM
pondrunner's Avatar
Default gear ratios
If I changed the gear would I have to change the chain every time. Or could I keep it. This is to see if i like that gear
Old May 13, 2004 | 04:09 AM
Default gear ratios
If you go bigger on the rear sprocket you will need a new Longer chain. If you go smaller on the sprocket than just cut the chain down if it is in good shape.
Old May 13, 2004 | 08:44 AM
pondrunner's Avatar
Default gear ratios
do you know what the sproket size is on a 85 110. But I think that might just get a 45 rear sproket
