welding on rim
welding on rim
If the part of the rim you are welding on does not touch the tire you should be ok if you weld for short periods and cool it back down quickly with a wet rag. Make sure there isn't any fix-a-flat in the tire either or you will probably die. Welding+Butane=Death. It is amazing I can figure that out but I still don't know what 2+2 equals.
greg86hd
09-16-2015 12:32 AM
