Blue smoke
On startup, my 200m blows a fair amount of blue smoke, after its warmed up and ridin for a bit, it doesnt seem to blow smoke anymore, i recently did a rebuild, new piston, rings had the cylinder honed.....i know this is oil its burning..whats causing this???
[quote]
Originally posted by: ThrashAndCrashUntilItsTrash
Don't worry about the blue smoke YET.......q]...ive been pounding the crap outta this thing...like riding pretty hard, maybe itll pass up soon.....hopefully
Originally posted by: pfgm
u shouldent ride that hard after a rebuild but after the rings and gaskets r seated itll b fine
the breakin procedure of new rings or a new piston is just as if it was new. for the first 5-10 hours of operation, no more thanone-third throttle should be used and speed should be varied as much as possible within the one-third throttlelimit. prolonged stedy running at one speed, no matter how moderate, is to be avoided, as is hard acceleration.following the first 5-10 hours of operation, more throttle should not be used untill the ATV has run for 100 hours,and then should be limited to short bursts of speed untill 150 hours have been logged.
tookin word for word from Clymer's honda shop manual fo 200cc engines to 350cc engines between 1984
and 1987
and 1987
jrooker6
Apr 23, 2016 07:36 PM
