250r from 3 wheeler and into dune buggy
#15
i wonder if you could switing the bearing carrier and axle around on a later year R. the rear caliper would need a bracket fabed up. i dont see where it would be a problem because you have to rig some kind of custom rear braking system anyway. just throwing out ideas.
#16
#17
Another question. How much would this engine go for? 82 250r, Has lots of compression, complete trans and exhaust. No carb, cdi or coil.
Im thinking about going for a larger engine in this buggy. Im beginning to think a larger frame than what I was originally thinking will be appropriate.
#18
if you use a quad swingarm on this thing, it will probly be at least 9 feet long, which equates for a heavy go cart. a better suggestion might be to use some sort of polaris independent rear suspension. i believe polaris uses a chain drive for their diff, you could use the hubs, cv axles and polaris suspension and brakes. and if you put all this together, you lookin at probly a 500 lb machine empty....id say its too much for an r engine of any kind to pull around. youd probly be better off with a larger displacment, chain drive 4 stroke......namley, a raptor or a ds650 engine. or......if you dont mind 2 stroke......get a nice snowmobile engine and attach a pulley to the polaris diff....that would probly pull it the best
#20
