200x idle problem
Old Aug 30, 2004 | 12:19 PM
Madwolverine's Avatar
Default 200x idle problem
Hey guys:
I'm posting this to assist others who may have a similar problem.
I bought a x that was in pretty good shape. The only problem was the idle. I adjusted it to no avail. Finally, I took the carb off to clean and inspect it. It was pretty clean so I was wondering what the problem might be. As I was putting it back together I found the problem. The o-ring that goes between the carb and the intake was missing. This caused a vaccum leak in turn causing the idle problem. The honda part had to be attained through a carb kit costing $21.00. I ended up using a CAT o-ring that fit fine and saved me money. The bike fired up and started idling perfect.
The same problem mentioned above could be caused by a cracked intake which is common on older ATC's.
Anyway, just wanting to help folks with problems.
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 31, 2004 | 11:33 AM
GlennJ's Avatar
Excellent tip!
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
