Hey ThrashandCrash????????????????
Old Nov 8, 2004 | 08:25 PM
newguy185's Avatar
Default Hey ThrashandCrash????????????????
Hey TrashandCrash, I was wondering what the top speed of your 200x is? Does it have much low-end for the woods? Do you have an aftermarket exhaust on it?
Old Nov 9, 2004 | 08:07 PM
dragracer789's Avatar
My 85 (5 speed) will go 55-60 with 20 inch tires tweaked to the max (stock gearing). 86/87 will go alittle bit faster because those had a 6 speed tranny. I love my X for the trails also,.
Old Nov 9, 2004 | 11:56 PM
Wes350x's Avatar
No, a 200x doesn't have too much bottom end for trail riding. They are good a trail bike.
Old Nov 11, 2004 | 01:24 PM
ThrashAndCrash's Avatar
LMAO [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img] NO it isn't a good trail bike, they are a good trail bike, LOL, j/k
My 200X tops out a 66mph +or- a touch. I am running 22X11X8 in the back, stock gearing, 10.5 to 1 compression, air filter, 110 main jet, and a sorta stock exhaust (it looks stock, but the guts are hollow) It makes for a GREAT trail bike. It has enough low end power to do power wheelies in 2nd gear no prob. All I did for the first year I had it was ride in the woods in southern Missouri and I loved it. A couple months ago I went to a 280 acre ATV park and that is when I decided I need a little more (looking into a 2-stroke dirt bike).
Old Nov 12, 2004 | 02:39 PM
Wes350x's Avatar
All I meant was it DOESNT have TOO much power, AND they are good trail bikes.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 16, 2004 | 02:43 PM
MY86ATC350X's Avatar
LOOKS LIKE THRASHANDCRASH HAS THE SAME FRONT TIRE THAT I HAVE ON MY 350X LIKES NICE ON HIS 200X.
Old Nov 17, 2004 | 04:09 PM
Cdogg's Avatar
Thrash, how are you measuring top speed on your 200X? 66mph is very very fast for a 200X with the mods you have listed. I also have a 84 200X with the following mods: 10.25:1 Wiseco (.040" over), Web cam (grind 214), ported head, rejetted carb w/ UNI, DG pipe, 1 tooth bigger counter to make up for my 20 in. Shredders. It is hangs very close to a stock 350X through the gears, its just about 5mph slower on top end. I usually see 64 mph on my GPS. I have a friend with an 86 200X that was raced, it has a white bros cam and basically the same mods as mine an his runs the same top speed (within .5 mph)
I have to fix my 200X-- tranny problem with 3rd gear, oh well it took twenty years lol
I recently moved to LA but I am from the St. louis area.
I plan on going to St. Joes the Saturday after Thankgiving.
Old Nov 17, 2004 | 04:45 PM
Riding next to a motorcycle with a speedo. Also my 22" tires are more like 24's at top end also, taller the sidewall, the taller they get by centrifugal force, that may be the difference. I have no doubt you would get to your top end faster than I would.
Old Nov 17, 2004 | 07:30 PM
short4stuff's Avatar
so when you put the webcam did you change the valve springs like webcam says to?..
I have an 84 200x... I would like to mod abit but i am not really sure if its worth it.. i mean there is like no such this as a 350x or 250r around here... my 200x was hard enough to find...
Old Nov 18, 2004 | 05:35 PM
Cdogg's Avatar
Yes, when I rebuilt mine 4 years ago I did the following:
-ported the head
-new rockers
-new valves
-3 angle valve job
-new HD valve springs
I replaced other wear items such as timing chain and gears etc.
My 200X had a XR200 head, cam, and piston before the above mods and it was flat track raced in 84. I then put the XR parts, pipe, on my lil brothers 185s, after these mods that was the best running 185S I have ever seen
I have no problem beating stock 300EX, Warriors, and Blasters with my mods
So whether or not it is worth it is entirely up to you.
I also have a new 28mm Mikuni flatslide sitting in a box that should compliment my existing setup, but it will take some engineering to get it to work.
Hope this info helps your decision...
