Rebuilt my carb and it still runs poorly!
Old Dec 22, 2004 | 03:45 PM
barrister1's Avatar
Default Rebuilt my carb and it still runs poorly!
Actually, if my thinking is correct (and maybe someone out thgere can verify this), raising the clip would lower the needle, which would mean that you're actually making it leaner rather than richer. Try moving the clip down, which in turn should raise the needle, thus making your mixture richer.
Old Dec 22, 2004 | 03:59 PM
TJ185s's Avatar
My bad. I meant to say that I lowered the clip which would make it run richer.
Old Dec 23, 2004 | 12:07 AM
TJ185s's Avatar
Ok, so I checked the fuel tank filter and it's clean. The carb is clean as well. The float is set to .500 inch. I am going to give it another try tomorrow. It has 125 psi of compression. Is this low?
Old Dec 26, 2004 | 07:47 PM
TJ185s's Avatar
My arm is killing me. I don't know what to say other than this ffffnnnn atc is getting the better of me. The carb is rebuilt, a nos stator assembly, valves are set and triming is on the money. Why is the damm thing so hard to start?
Old Dec 26, 2004 | 10:51 PM
  #15
catchmeifucan's Avatar
check the electric. Test each connected end.
Old Dec 26, 2004 | 10:52 PM
  #16
And try a new plug wire.
Old Dec 27, 2004 | 02:37 AM
  #17
hondabuster's Avatar
Hows the mixture screw set? About 2 1/2 turns out from seated? Air filter and cover on?
It might just be too lean for these cold conditions.
Have you checked for spark?
If you have someone to pull it with a tow strap while you bump start it, might be the best way to get it going. If its posible to start, it will with bump starting, and its much easier on your arm.
Old Dec 27, 2004 | 09:30 PM
  #18
skinny's Avatar
try taking the tube that runs from you carb to your air box off and see if it runs better or try a different coil the coils on those dont last more than 20 yr
HELLO
Old Dec 27, 2004 | 10:05 PM
  #19
TJ185s's Avatar
Ok, so I got it to fire today after adjusting the valves again. When I did it the first time and ran it for awhile they must have reseated themselves. But I still have the bogging problem. It has a new NGK D8EA installed and while it was running I took off the air filter and noticed that when I snap the throttle open it really chokes itself on gas. Meaning I can see gas spitting out of the carb. If I feather it up to full throttle it will go but who wants to ride a bike like that? The jets are stock (pilot#38 pressed in/main#95) with the moose after market needle installed on third clip position. To me this sounds like a pilot jet problem. I pulled the pilot out and made sure it was clean then pressed it back in again. I don't know what else to do. Any ideas? Thanks
Old Dec 28, 2004 | 01:29 AM
  #20
In the intake side of the carb, looking thru the venturi, theres gonna be one or two very small air bleeds, around the diameter. My guess, is one of them is plugged. One will go to the idle circuit, and the other...if there is one, is for the main.
