have some clutch problems on my 81 atc200
you will need to buy 2 qts. it will take a touch over 1 qt. Also for a little hint........check the oil by NOT screwing in the dipstick. Only touch it to the case and check it. If you screw it in then screw it back out, you will end up a 1/4qt low or so.
