What do I need to convert CDI to points ignition?
cdi converting to points ignition?
The original engine had cdi. I found one cheap with points. I dont think I can switch electricals on engine over from one to other, correct me if I am wrong. So I need to get a coil for the older points type engine. I dont think the cdi coil will work, again correct me if I am wrong. What else do I need, if anything?
The original engine has a bad trannie.
Thank you
Larry
Thank you
Larry
Customer Service #1
05-15-2020 08:46 AM
Elkaholic
09-06-2015 02:44 PM
110, atc, cdi, contact, conversion, convert, converting, convertion, engine, ignition, point, points, rs100, small, switching
