85 200x wont start
Old Jan 16, 2006 | 02:53 PM
3wheelinkid's Avatar
Default 85 200x wont start
I just recenty bought a 85 200x and it had a smashed stator cover so i found a used one put it on and now there is no spark.
Need help please
Old Jan 16, 2006 | 03:53 PM
ThrashAndCrash's Avatar
get ahold of an Ohm meter and Ohm out the wires from the mag to there respected components check close where they go through the stator cover
Old Jan 25, 2006 | 04:23 PM
we borrowed a stator form a friend and it has spark but not very much. some kicks it will barely spark and others it wont spark at all
Old Jan 31, 2006 | 07:41 PM
CYCLONEandATC125M's Avatar
Now that you have a spark, you may need a hotter plug, as some of these machines get older they need a little bit hotter plug. Have you checked your magneto too to make sure nothing is wrong with it.
Old Feb 6, 2006 | 04:09 PM
i bought a new exciter coil and it still dosent have spark,
Old Feb 6, 2006 | 07:25 PM
Are you a member of www.3wheelerworldforums.com ? If you arent I would suggest registering and I know someone will be able to help you there.
It is a good site and I ama member of it too[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 20, 2006 | 09:57 PM
kodybear's Avatar
if the wheeler had been sitting a while alot of the wiring of gotten corroded
and needs cleaning check first the coil wires, and then i had the stator wires
break on me once and would start and then die cause wire break apart
good luck
Old Jun 27, 2006 | 10:41 PM
crazyrider1's Avatar
hello
your friends worked but not verry well
buy a new one - dennis kirk has them for 75.00
ricky stater sells them 2 i believe but there alot higher
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
1000gade
May 27, 2015 12:37 PM
mpm
Apr 6, 2004 07:02 AM
bigmanm
Jun 28, 2000 10:34 PM
86Honda200SX
Jan 31, 2000 10:43 PM
