gas tank problem
I have a metal gas tank and it has some pin hole leaks in it i tired to use sotter witch worked good on the small holes but these holes are too big and it the crease of the tank does anybody know where to get some tank sealant for the inside and the outside???
THANKS!
THANKS!
Any decent bike shop sells POR-15, Creame or Red-Kote.
Aviation shops, race shops use it for fuel cells
Red Kote is the best if you can find it, followed by POR, then creme.
A plastic clarke is a good option for a hundred bucks.
I used red-kote on an 85' 110. It was like $26 at an auto parts store. It worked great. Used a small fan blowing down into it for a quicker dry and used two coatings. Make sure you put something in the gas holes so none leaks out. I just used two rolled up pieces of paper and pulled them out when red-kote was dry. I had heard good things about all the liners. I got red-kote because it was the only one that I could find after stopping at four auto parts stores. Good luck.
