Piston Sleeves
Old Mar 20, 2006 | 10:56 PM
HondaAtcRoxz's Avatar
Default Piston Sleeves
you should use a torch converter setup. it will be the best bet for your set up and it will flat out FLY!!! if the motor has a clutch on it i think the golf cart should have the right kind of clutch for it if not i would spend the money to do that. like i said before you should either use a lawn mower steering system or even a car gear box.
Old Mar 20, 2006 | 11:54 PM
luckyboy's Avatar
Yeah that is what I'm gonna due. I already have a torque converter from the snowmobile. Hopefully I can get that pretty closed to finish while I'm waiting to get my new gaskets and piston in.
On another note.
Is there anything special to know about Honing a piston cylinder?
Old Mar 21, 2006 | 12:02 AM
Yeah make sure you dont got in too far or out too far. My dad honed my motor and he nicked the $hit out of the cylinder wall and it smoked like a freight train. lol also i would take the crank out too if you havent already it makes it much easier. and use LOTS of lube! messy but needed.
Old Mar 21, 2006 | 12:06 AM
luckyboy's Avatar
crank?
Old Mar 21, 2006 | 12:48 AM
  #15
the crankshaft that the piston and piston rod is hooked too.
Old Mar 21, 2006 | 12:52 AM
  #16
luckyboy's Avatar
oh yeah i've completely removed the top end of the engine.
Is there anything in the bottom end that needs to be replaced?
Old Mar 21, 2006 | 12:56 AM
  #17
I dont know, I would just check to see if all the bearings are tight... just make sure there is nothing in the bottom of the motor that you can hit with the hone.
Old Mar 21, 2006 | 01:02 AM
  #18
luckyboy's Avatar
ok thanks man
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
