~spark!~
Old Apr 17, 2006 | 03:01 PM
xpslayer's Avatar
Default ~spark!~
ok, the guy w/ the 1982 atc 200... tryed everything/// magnito puts out 12 volts paulse generater has 30-40 continuety, ignition coil 2-.4 continuety, MODULE, IGN CONT my dad checked @ honda... i only have 2 volts coming out of thepaulse generater. i don't thing thats enough to make a spark... i did the paulse air gap to .6mm. what else could stop my spark?
Old Apr 20, 2006 | 02:01 AM
shelbert's Avatar
Default ~spark!~
I don’t have the specs on your bike but the checks for the coils are mostly continuity checks for testing. The numbers you gave are not even close to what my 84 200 big red is supposed to be. You can probably get all these specs at the dealer, most will let you look at the manuals there.
With that said on the old bikes like this I find it’s usually a connection problem, corroded on/off switch, or the exciter coil. Never seen an Ignition coil go bad although I have seen them not fire if not grounded properly, CDIs I have rarely seen go bad but have seen the leads get corroded as well in there.
No fire problems in my experience are usually pretty easy when you look back but a pain to find. I just spend 2 days fixing a no fire for an 85 trx250 and it ended up being the neutral safety switch had come unplugged when jacking the bike up to change the tire ( which must have loosened it because it didn’t come loose till I was 10 miles into the woods) under the swing arm. I didn’t even remember there was a plug there until I was tracing the harness for damage.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
