1984 250R compression???
Old Jul 11, 2006 | 09:16 PM
JTVette's Avatar
Default 1984 250R compression???
Hi... I recently picked up a 84 Honda 250R ATC & I'm having some trouble getting it started. It seems to be getting plenty of gas & spark, but I'm thinking it's a compression problem, & was wondering if anyone knows what the compression should be on it, & what's the proper way to take the compression test on this engine? The result that I got, after the 3rd or 4th kick, was appx. 105-110 lbs. It seemed to go up appx. 30lbs. per kick, to a max of 105-110. That was also done on a cold motor, (as I'm having trouble getting it to start). Thanks for any help you can offer, I appreciate it very much. Thanks again, JTVette...
Old Jul 11, 2006 | 09:28 PM
JkAss's Avatar
Welcome to the forums! That sounds low for the compression. I believe 135-150 psi is about right for a stock 84. Make sure you are holding your throttle wide open when kicking it over. 5-6 kicks should give you your max reading. Yes a cold engine is fine when checking it. Good luck and I'm sure more people will chime in with some more help.
Old Jul 13, 2006 | 04:22 AM
JTVette's Avatar
Thanks for info, JkAss. I don't think I had the throttle open at all while doing the test. So I'll re-test it with the throttle open & see if it's any different. And thanks for the welcome too. These forums are great, been doing ALOT of reading in here lately, & got alot more still too do. Thanks again. JTVette...
Scooter's Shop
Oct 9, 2015 02:09 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Steeldon
Sep 9, 2015 09:38 AM
