200x kick start gear slipping
Old Jul 15, 2006 | 06:47 PM
Campbelltx's Avatar
Default 200x kick start gear slipping
Hi, On my 1985 200x the kick start gear is slipping. Do you just have to replace the 2 gears behind the cover behind the kickstarter? I look at them they look good no chips or damage. I lined them up on the two punch marks. I also have a spare 84 200x engine but the gears are differant sizes. Anyone know if that is all you have to replace?
Old Jul 19, 2006 | 09:39 PM
HMFIC's Avatar
The two gears are not your problem. You need to replace the kick starter spindle and you have to split the cases to do so.
Old Jul 21, 2006 | 07:10 PM
arizonatractor's Avatar
Your other reply has it just right.
Old Jul 21, 2006 | 07:21 PM
Campbelltx's Avatar
Would the spindle off a 84 200x engine work. Or should i get a new one. Where can you find them. Bike bandits site said they are disscontinued. Also do you replace both the long and shorter spindle. There are two shown on the slide.
Old Jul 21, 2006 | 07:43 PM
Joshwfl's Avatar
You can get the kicker shaft from Service Honda for $33.50
Go to www.partsfish.com They have the spindle for $62 and the shaft for $52.
Old Jul 21, 2006 | 08:53 PM
HMFIC's Avatar
Don't worry about the short shaft or either shaft really. If you are looking at a microfiche or a repair manual you will se the the two peices you need to replace. I can't really explain what the look like. I highly recomend a clymer manul before starting or ordering anything.
Old Jul 21, 2006 | 11:05 PM
82 to 85 is the same
86 250r
86200x
84 klt 250
71 trail 70
02 xr200r
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
4trax300ex
Jul 29, 2000 11:41 AM
rking85
May 20, 2000 11:01 PM
