1985 ATC250SX Starter makes a grinding sound when engaged, and kick start slips, any ideas?
Old Sep 5, 2006 | 11:51 PM
greenishiguana's Avatar
Default 1985 ATC250SX Starter makes a grinding sound when engaged, and kick start slips, any ideas?
I have a 1985 Honda atc250sx. It is in great shape, there are two problems, one, the lights are always on, the headlight on/off selector switch, does not work, I was wondering how to fix that. The second is that when I press the start button, the starter turns, but its got a very bad clanky, grinding sound. It sounds like somethings missing teeth and pieces are slamming together. Also, when I use the kick start, it feels like its slipping a little, or not quite catching the teeth on the gears. It still starts, but sometimes it takes a couple trys to get a good kick. After I kick it, it makes a whirring sound like there something spinning freely, and I have to wait for it to stop before I can kick it again. And finally, when I shut the motor off, the sound of something spinning freely is there again and then it stops with a clunk. And last but not least, when I first start the motor, there is a really bad clanking sound while its running, I thought at first that it was something in the motor that was bad, but I find that once its running, if I tap the start button a couple times, it will go away, then come back. After a couple times, it goes away completely and the motor runs beautifully, so I tend to think its not actually a problem with the motor but something in the starter, flywheel area. I dont know much about these machines. Please make any suggestions that you can come up with. Somebody told me awhile ago that it is a common problems with these particular atc's but they didnt elaborate. I much appreciate your input.
Thanks
Ben
Old Sep 6, 2006 | 12:38 PM
ThrashAndCrash's Avatar
No offence Ben, But it is time to buy a book and pull that side cover off........there is nothing your going to be able to do from the outside, and no way of telling what gear is messes without a visual.
Old Sep 6, 2006 | 12:44 PM
AND Welcome to the forum!!!!!!
Old Sep 6, 2006 | 01:09 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum greenishiguana! [img]i/expressions/face-icon-small-smile.gif[/img]
Does the ATC work well except for these noises? Can you shift thru all the gears?
T&C is right though, you need a book and to take the clutch cover off.
Old Sep 6, 2006 | 11:30 PM
Hey, yes the three wheeler works great once its running,and shifts through all 5 gears and reverse without flaw. The motor runs smoothly with no odd noises. Any idea where I can get a book for this particular atc?
Thanks
Ben
Old Sep 7, 2006 | 05:13 PM
oldkawi's Avatar
go to 3 wheelerworld.com Deepa has his manual section up again (free)
Your kicker is propably the one way (sprauge bearing)
starter is probably bad bearings in the starter
Old Sep 23, 2006 | 08:21 AM
spcasml's Avatar
when you go down hill on it a steep one does it take off like its out of gear
Old Sep 23, 2006 | 09:57 PM
No, when I go downhill, the motor slows the trike down just like its supposed to. There is no problem with the way it runs or operates as far as I can tell, just when its being started.
Old Sep 25, 2006 | 09:04 AM
spcasml's Avatar
e-mail me at socasml il help you threw fixing that problem i have 4 250sx and 3 extra moters so i think i can figure it out for you
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
jayking232003
Jun 9, 2015 02:54 PM
rking85
May 20, 2000 11:01 PM
