shifting problems
Old Feb 20, 2007 | 10:33 PM
skippy123abc's Avatar
Default shifting problems
i have a 1985 honda 110 atc. i have noticed that when the motor gets hot it will slip out of gear. at first i thought the oil was too thin so i went from 10w30 to 10w40, past this i dont know what to do please post back
Old Feb 21, 2007 | 03:37 PM
popup's Avatar
use motorcycle oil. car oil is not good for the clutches did you adjust the clutch.
Old Apr 6, 2007 | 01:51 AM
85Rrider's Avatar
My sons ATC70 had a similar problem. turned out the part which holds the damn thing in gear was broken.
It was called a 'shift drum stopper'. (Im sure the 110 has a similar part)
here is a pic (for the 70) -> http://dratv.stores.yahoo.net/70shdrst7.html
you'll need a book to open er' up - if you want to be able to put it back together.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
