Removing the flywheel :(
Old Aug 16, 2007 | 11:56 PM
NewfieBish's Avatar
Default Removing the flywheel :(
So i found a really great task there the other day, trying to remove the flywheel. So far i have had no luck whatsoever, i tried prying and tapping and then i bought a puller and i still cant get it :S any suggestions, does anyone have their own way of doing this?
Old Aug 17, 2007 | 12:02 AM
HMFIC's Avatar
it shouldnt be any problem with a puller. Just remove the nut and washer install puller and remove flywheel. Its really easy with an impact wrench.
Old Aug 17, 2007 | 09:58 PM
NewfieBish's Avatar
yeah ill try the wrench tomorrow, but i used the puller with a normal rachet and the puller keeps wanting to move off the crank, the part that screws into the crank keeps trying to slip off, and eventually it does. I had it really tight and still nothing, is that weird? shouldnt it come off easy with a puller?
Old Aug 18, 2007 | 11:33 AM
lawnboymelvin's Avatar
tighten the puller as much as you can without it slipping off. it shouldnt slip of anyways. but tighten it good and tap the puller and the flywheel with a small hammer. it should pop off
Old Aug 18, 2007 | 12:20 PM
HMFIC's Avatar
Yeah, the hammer trick definatly works. Once you break it loose it will come off easy.
Old Aug 18, 2007 | 12:40 PM
NewfieBish's Avatar
alright. i tried tightening the puller really tight.. to the point where i thought it'd ruin the threads on the crank, then i tapped with a hammer, kept tightening and tapping, and still nothing :S maybe i should try heating it up or?
Old Aug 21, 2007 | 09:27 PM
haywoodjalikme's Avatar
You are using the 'puller' which is actually just a large diameter fine thread bolt which threads into the flywheel and against the crank right?
Never hit the flywheel itself with a hammer!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Canamaniac!
Sep 15, 2015 06:19 PM
