Honda 200M gear oil?
Old Jan 26, 2008 | 05:35 PM
jtbel's Avatar
Default Honda 200M gear oil?
What kind does it need and how much?
Old Jan 26, 2008 | 06:08 PM
rodeo999's Avatar
Have you ever looked at http://www.3wheelerworld.com/y...200mpicturepage1.shtml
Old Jan 26, 2008 | 09:19 PM
jtbel's Avatar
Yes, I have. I've looked all over it, and I don't see where it says anything about what kind of gear oil I need for my 200M and how much. Thanks for the reply, but does anybody else have some information that might help.
Old Jan 27, 2008 | 12:29 AM
jtbel's Avatar
From what little info I could find on this subject, I beleive there is no gear or transmission oil used. I'm guessing everything gets lubed by the engine oil. I was confused when I removed the cover containing the stator housing (what the recoil starter is mounted on), and a small amount of oil came out. I'm guessing it was just engine oil that could not flow out by gravity. If I've come to the wrong conclusion, please let me know.
Old Jan 27, 2008 | 08:50 PM
joshjines's Avatar
on the right side of your motor there is like a plastic or rubber screw thats where you put your oil and the oil pump pumps the oil threw the hole motor i always bye 10w 40 for my 185s and i put just a litile more than half in it and she runs like a champ
Old Jan 27, 2008 | 10:29 PM
jtbel's Avatar
Yeah, I understand now that it uses just motor oil to lube everything. I'm getting a leak from the recoil starter. If I understand correctly, there should'nt be any oil going to the stator housing and recoil starter. I'm assuming I need to replace the big round seal that the flywheel goes into. Sorry, but is it called the flywheel? (the part the recoil starter turns) Anyway, what is that seal called? Thanks
Old Jan 31, 2008 | 05:12 PM
joshjines's Avatar
ill let you know i have never had to replace it and yeah it is called a flywheel
Old Feb 1, 2008 | 03:24 AM
jtbel's Avatar
Thanks for the reply. I went to the local Honda parts place and ordered one, they listed it as just an oil seal. I'm thinking it should take care of the leak problem. I don't see any other route for the oil to take to get to the recoil starter. Other than the replacement of the front fork assembly (front wheel alignment is way off), I should be pretty much done with getting her into riding shape.
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
CRamshaw777
Jul 18, 2015 05:46 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
