will a cdi 110 head fit an early 110 non cdi?
It will change but you may run into an issue with the cam length on the CDI cam
I have run into issue when changing to an aftermarket Perf cam
I know the internal part of the cam is direct fit but where the advance mecanism fits
The older points cam is shorter
Not a problem if that is the case use the cam with the points ignition
I hope this makes sense to you
Good luck Ray
2-82 110s
1- 82 185s
2- 400EX
Good luck Ray
2-82 110s
1- 82 185s
2- 400EX
jrooker6
04-23-2016 07:36 PM
1ArmBandit
55
10-14-2015 09:03 PM
Quadzilla Heritage
09-25-2015 01:39 PM
09-23-2015 06:23 AM
