how can I reduce engine vibrations?
Old May 15, 2008 | 11:47 AM
JimVT's Avatar
Default how can I reduce engine vibrations?
I am running an atc 110 motor in a bike and it is geared low . Now that the motor is run at higher speeds than normal I have lots of vibrations comming from the motor. Can this be reduced somehow? I have it bolted directly to the frame . Has anyone seen or know of a motor mount that will reduce vibrations? I just don't have the room to put a larger motor in and run it slower .
Can the motor be balanced easly?
Jim
Old May 15, 2008 | 01:17 PM
McDerry's Avatar
Spring Eye bushings to replace the tabbed mounts on the frame. Will absorb alot of the vibrations
Old May 15, 2008 | 01:38 PM
JimVT's Avatar
I need a little more help on the spring eye bushing. I never heard of them.
Search didn't help me on them either. Maybe I know of them by another name.
Jim
Old May 15, 2008 | 02:25 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
You might try drilling out the engine/mounts and using larger bolts. Or adding a brace some where to reduce vibrations.
Old May 16, 2008 | 05:09 AM
McDerry's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JimVT
Jim</end quote></div>
As in like what they use on on spring eyes in a vehicle. just google up rubber bushing.
Theres no counter balancer in the motor, so you will have to isolate the motor from the frame via a vibration absorbing medium aka rubber bushings.
Another option is if its just bothering your hands, fill the handlebars with RTV sealant.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
