1986 200S honda 3 wheeler timing info needed
Old Jul 2, 2008 | 03:37 PM
TimberedWolf250's Avatar
Default 1986 200S honda 3 wheeler timing info needed
I just recently picked up a no running 86 200s was told it has a stuck valve or bent valve, however I took out the sprk plug and you can watch the valves open and close when pull the rope. so I am thinking it is not a valve problem, I do have spark there is some compression but I think it is firing at the wrong time.
I had a manual but I had lent it out and have not gotten it back yet.
I am looking for the timing marks as how to time this machine.
thanks
Craig
Old Jul 3, 2008 | 11:26 AM
rjdad's Avatar
84-86 ATC 200s
igination timing initial 10 degree plus/minus 2 degree BTDC at idel
full advance 30 degree plus/minus 2 degree BTDC at 3,350 rpm
I have a manual, if you can give me an email address I will attach the information you are requesting.
Old Jul 3, 2008 | 01:23 PM
Thanks rjdad
Honda mechanic shot me the info last night..
in the process we did pull the head and found that the intake valve was not closing all the way, due to the p/o who retapped or rethreaded the plug hole ran it right down into the intake valve. burr city now needs new valve..
but the piston and walls look great like brand new can't wait to put the ne w valve in and try it.
again thanks for the offer and Honda Mechanic thanks again
Craig
Old Jul 3, 2008 | 03:41 PM
rjdad's Avatar
Your welcome and gald to hear that you have your baby up and running
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
lovinhonda
Jan 25, 2000 09:17 PM
Joeg
Sep 27, 1999 11:53 AM
