250SX w/ 350X front end??
Ok, the photos can be found at this address
http://photos.yahoo.com/valerius400
Click on my photo album and you should get a good look at what it now looks like. I also posted some before photos that will help visualize the difference. There are some others of my 99 Sport.
I am still working on the ATC and have a long way to go. I am still trying to figure out what to do about the rear end. I have a plan though. The top cap of my 99 Sport Fox shock has gone missing, thus the spring is currently resting against the frame member where the top is bolted. Since it is rebuildable, I am going to rebuild it and try to fit it into the ATC. Both top & bottom bushings measure the same as the stock ATC setup. The only problem could be in the height. We'll see (I am hoping this will work-8.5"!!!) The sport is going to get a 10.5" Fox w/ remote resivoir (like the current Scrambler models).
After the ride has been modified, I will start to work on the appearance; new plastics, paint, & rear wheels. Then I will go into the engine, carb and air flow.
Then the ATC should be able to impressively go on the trails with all the others and not feel like a tired old dog!
Thanks for asking about the photos. I had forgotten. I will keep posting new ones as the upgrades continue. This should be an experience.
