1980 Honda atc 110 no spark help!!! Please
Old Sep 1, 2020 | 10:41 PM
Powerlifter123's Avatar
Default 1980 Honda atc 110 no spark help!!! Please
I have no spark. I have pulled flywheel. Cleaned magneto and stator. Replaced all electrical connections. Replaced points and set gap. New ignition coil spark cap and plug. I have switched back and forth from original to new ignition coil still no spark. Have original one in place now with new spark cap and spark plug. F timing is setup up with points just beginning to open. Cut kill switch wires so they are just bare and open. Have tried both ways with open and twisted together still no spark
what do I do? What can I check and how do you check with multimeter? What should I be reading? How do Iknow if magneto or stator is bad? Anythingelse I can check?
Old Sep 1, 2020 | 10:43 PM
samdecuir
ATC 3-Wheelers
Oct 29, 2018 04:42 AM
ringosmash
1) Engine problems..
Sep 10, 2014 08:57 PM
Davidxfields
Honda Side by Sides
Aug 2, 2013 11:35 AM
crispy1960
ATC 3-Wheelers
Nov 18, 2009 03:14 PM
