fuel
Old Oct 5, 2003 | 05:31 PM
Blaster2fast's Avatar
Default fuel
for my kfx400
when i run the following compressions how much octance should i be using.
12-1
12.5-1
13-1
Old Oct 5, 2003 | 07:01 PM
dsracer666's Avatar
Default fuel
you should run between 102 and 110.
Old Oct 5, 2003 | 07:08 PM
Default fuel
for which compression? all of them? i need to know specifics.. my dad works at the williams refinery and i can get my hands on any octance i want... need to know exactly which ones to run at which compression. for optiumum performance
Old Oct 5, 2003 | 08:51 PM
dsracer666's Avatar
Default fuel
too much octain is never bad just a waste of money.
102 for the 12/1
106............12.5/1
110.............13/1
you may be able to run less but with this you'll be safe.
Old Oct 6, 2003 | 02:46 PM
Flynbryan's Avatar
Default fuel
Any thing over 100 for any of those compression ratio's will be fine.
Old Oct 6, 2003 | 05:07 PM
Zhvonte's Avatar
Default fuel
I run 114 octane for my 14.5:1 compression.....
13.5:1 needs 110
13.0:1 needs 108
and anything below that will vary from around the 100 octane, plus or minus...
Old Oct 8, 2003 | 03:20 PM
shackattack's Avatar
Default fuel
you have access to any octane fuel you want. you are a very lucky guy!
Old Oct 8, 2003 | 10:12 PM
SANDMAN430's Avatar
Default fuel
sounds like life is good in alaska[img]i/expressions/face-icon-small-smile.gif[/img] about 105 should have it covered.
Old Oct 9, 2003 | 06:31 PM
2quick87BuickGNational's Avatar
Default fuel
Just to add a little to your thread,...
My racing season for my car is near an end,and I happen to still have
3/4's of a pail of 114 octane fuel,....and seeing as I'd hate to waste it(teehee) I was wondering if it would cause any problems if it "happened" to fall into my "STOCK" Z400? Probably not, but I thought I'd best check with you guys,.....
Thanks in advance,kyle
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
