BEST mods for the YFZ450??
Old Dec 2, 2003 | 04:22 PM
DrakeSpeed's Avatar
Default BEST mods for the YFZ450??
I need to know which mods would be best cam mod or Yz cam? How about that grey wire?
Old Dec 2, 2003 | 04:23 PM
DrakeSpeed's Avatar
How about the pipe, curtis sparks or trinity??
Old Dec 2, 2003 | 05:05 PM
FX1660R's Avatar
forget it about the gray wire the yfz dosn't have
cam mod yes great mod don't borther with the yz cam both have same spec etc.... expect for the timming
mark do some search you will find "how to" and it's FREE ;-)
Old Dec 4, 2003 | 01:39 PM
DrakeSpeed's Avatar
Thanks FX1660r!!
Old Dec 7, 2003 | 02:47 PM
thomez's Avatar
I don't believe they are the exact same you will be changing the decompression mechanism a little by retarding the stocker. Not many problems with it so far though.
I have been told by a few MX riders that the cam mod only helps on the top end and hurts the bottom. The MX riders I have heard of have all put the cam back in stock position for keeping low end power.
Best way is to do it and see for yourself!
As far as a pipe, Sparks, Trinity, HMF, Yoshi, GTYR, all should be very good and very close in performance. Pick your poison!
Old Dec 7, 2003 | 03:20 PM
FX1660R's Avatar
if you want to see the difference between stock cam and cam mod see my pics there is the dyno result before and after the cam mod
and yes i forget to say the decompression pin will be a bit off but not hurting the motor ,maybe a little hard to start
Old Dec 7, 2003 | 03:26 PM
thomez's Avatar
Thanks for sharing the dyno results, and cool pics!
Old Jan 15, 2004 | 10:58 PM
atvchik's Avatar
Where can i buy a yfz for my boyfriend.
Old Jan 16, 2004 | 03:38 AM
Disturbed_81's Avatar
Uhhh.... well you could try the yamaha dealership
Old Jan 16, 2004 | 11:01 AM
LT80's Avatar
LT80 Expert
What you guys will find that you need is: frame supports in the front shock area.
I hear Jones wiped out a YFZ frame at the Olympics. He was also blistering fast!!!!
