Can't keep it on the ground.
Old Apr 5, 2004 | 04:58 PM
RJay's Avatar
Default Can't keep it on the ground.
Does anyone know how I can keep the front tire on the ground. Every time I get a little to much traction, I have to let off.
Old Apr 5, 2004 | 05:01 PM
maddog56's Avatar
Lean baby lean. Sit on the handle bars if you have to.
You can increase air pressure in the rear tires, or get some different tires that will slip more.
You can lower the ride height.
You can get an extended swing arm.
You can get a arms moved forward.
You can slip the clutch.
Old Apr 5, 2004 | 05:08 PM
Bradracer18's Avatar
Yeah I used to have that problem with my pred...but you get used to it, just lean forward, elbows up and give it he!!. Ride'r in the air if you have to, but don't let off.
Old Apr 5, 2004 | 05:45 PM
RJay's Avatar
Thanks for the tip, I'll just lean in deeper then. I'll also try adjusting the tire pressure. Now that you mention it. The pressure might be a bit too low.
Old Apr 6, 2004 | 01:56 AM
LT80's Avatar
LT80 Expert
Longer swingarm.
Old Apr 7, 2004 | 11:21 PM
DIGGEM's Avatar
Put one of these on it
http://community.webshots.com/photo/...30463765nHvNbF
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
hueby
Aug 29, 2015 08:34 AM
Rooky
10
Jun 23, 2015 09:35 PM
BONER
May 19, 2001 02:18 AM
quadnut
34
Apr 12, 2000 05:33 PM
