Popping the Clutch???
Old Apr 25, 2004 | 03:04 AM
Machster22's Avatar
Default Popping the Clutch???
OK, I just bought a kfx, it does wheelie's easy, but I've never understood what popping the clutch is. Is it where you're going and when you go to shift you hold the clutch and givie it gas and let out??????
Old Apr 25, 2004 | 05:14 AM
Bradracer18's Avatar
Yes, popping the clutch refers to reving the engine, and dropping the clutch(releasing it). This is usually done from a dead start, and is about the only way to do it when you drag race.
Old Apr 25, 2004 | 11:15 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
beware it WILL damage your clutch eventually
Old Apr 25, 2004 | 12:15 PM
SANDMAN430's Avatar
just riding wears the machine so it all comes down what do you enjoy.
Old Apr 26, 2004 | 06:31 PM
bagz's Avatar
its when you are stoped and you let go of the clutch quick and give it gas at the same time n u do a wheelie.
Old Apr 26, 2004 | 07:20 PM
Machster22's Avatar
I don't have to pop the clutch to do a wheelie, bagz. On my 4-wheeler I can be in 2nd gear and nail it and the front will raise up (without leaning back). And whenever I pop the clutc stading still (even leaning forward as much as I can) it always pops a huge *** wheelie. But i guess it's just how to do it right. Cause every now and then I wll get it to where it will comes up not as high. But ok.
Old Apr 26, 2004 | 07:23 PM
hondabuster's Avatar
Wet clutches, have a built in dampening ( the oil film between plates), and as long as you arent on high traction surfaces, it probably wont hurt much to pop the clutch. Which means to let it release as fast as possible.
Now...if you have a dry clutch, like on a car or truck, yes, that will damage stuff if you pop that clutch.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
