starts
Old Oct 20, 2005 | 05:17 PM
mxracerwarrior's Avatar
Default starts
i have a warrior and every time the gates drop im praticaly laying on my handel bars and every time the gates drop i drop the clutch and the quad does a big wheelie and i have to hit the brakes to get it down and it seems like i never get a good start.
Old Oct 20, 2005 | 05:30 PM
RacinJason's Avatar
Default starts
Try a taller gear
Try using only half throttle until the clutch is out and apply the rest afterward
Old Oct 24, 2005 | 06:32 PM
warwgn's Avatar
Default starts
try starting in 2nd gear and stay leaning forward to allow a little wheel spin.
Old Oct 25, 2005 | 04:02 PM
Bradracer18's Avatar
Default starts
Just go home and practice a lot....that is how the best get to be the best, is practice. Practice on the same surface conditions too.
Old Oct 25, 2005 | 04:42 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default starts
On a Warrior I would keep it in 1st gear on the start. Just use some throttle control, you'll get the hang of it.[img]i/expressions/face-icon-small-smile.gif[/img]
If you really want to be fast, you can ride the clutch all the way out, but you will eat up your clutch fast by doing so.
Old Nov 2, 2005 | 07:46 PM
Raptor149's Avatar
Default starts
it's all clutch control and feathering. you have to let the clutch out with a smooth, steady speed. You can't just dump it and rev the gas simultaneously. If you have a stock clutch it's not going to like the abuse of a motocross start. But try in second gear, at least half throttle, and just feather the clutch slowly until you can start and only lift the front wheels a few inches. Starts are all about practicing.
Old Nov 5, 2005 | 12:29 AM
strongtyerYFZ's Avatar
Default starts
motox26- what do you mean ride the clutch all the way out? I havent heard that before.
I would start in second gear but i dont know for a warrior. If you have to hit the brakes then your just better off to not give it as much throttle. I think that would be faster. I dont know if this would help but say the gate drops, you let out the clutch and you think your about to do a "big wheelie." If your RPM's are up high enough try shifting up just a little early while you are still in the wheelie. That might help bring the front end down without losing too much acceleration. This is easiest to do if you just grab the clutch with 2 fingers (which you may already) and keep your foot under the shift lever so your ready to tap it when you feel its the right time.
Old Nov 5, 2005 | 11:29 AM
LT80's Avatar
LT80 Expert
Default starts
2 ways::
1) (my way) 1st gear start,let the clutch out then hammer it. (I got 5th out of the hole at Red Bud this way)
2) (daughters way) 2nd gear start, high rpm, get those tires spinning NOW!!! (she's a front runner)
Your doing it in the middle which as you see don't work well. [img]i/expressions/face-icon-small-smile.gif[/img]
Have fun. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 7, 2005 | 10:04 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default starts
Originally posted by: strongtyerYFZ
motox26- what do you mean ride the clutch all the way out? I havent heard that before. .
Basically feathering the clutch.
Old Nov 7, 2005 | 05:43 PM
Default starts
Ok, I just haddent heard it called that before. I see what you mean...
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
