HOw to remove stump for building a mx track?
Old Dec 29, 2000 | 12:46 AM
jeepin's Avatar
Ok me and Jviper 85 and another kid are building a MX track.THe part we have done was mainly sticker bushes and tiny tree's.And a couple medium size tree's(about 1 foot in diameter)We had my dad use his jeep's winch and pulled them out.(he couldn't get out and had to jump a 4 wheeler jump to get out.It was funny)
Now we are at the big tree's.We finally talked my dad into letting us use the chain saw so we can cut them down but how do we remove the stumps?
Any idea's? Thanks.
Old Dec 29, 2000 | 09:49 AM
Mudda's Avatar
Yank it with the jeep or do you have a 4x4 quad ?? if so dig around the stump and attatch a chain to it and pull it out witht he quad OR you can put dirt over them if u can cut them right down on the ground
Old Dec 29, 2000 | 10:34 AM
Lasher's Avatar
I think your best bet is to bury them.
You could use a jeep or ATV to try and pull them out, but it will take a lot of work, and wear on the machines. The manual labor you put into the stump, the easier it will be to get out. Start hacking at the roots with an axe and shovel. Get enough roots and the thing will come right out.
Remember, once you get the stump out, where are you going to put it? The bigger the tree the bigger the stump.
Also, keep the ground flat, you will need to fill the whole.
I would say dig around the base of the tree and cut the stump as low as you can get it. Then just cover it with dirt. Just be careful with the saw. For your safety and you Dad's piece of mind.
If you have the cash, hire a stump grinder guy or rent one. (if you can) That would be the best way, but it would probably cost at least $50 a stump. Good luck and have fun!
Old Dec 29, 2000 | 05:56 PM
surfer400ex's Avatar
when i was building my mx track in my backyard i used a stump grinder. IT was easy because my dad had one already. But if you can't get one use the stump as the base of a jump. Pile the dirt right over it.
Old Dec 31, 2000 | 04:10 PM
DIEhardRlDER's Avatar
Soak it in deisil (sp) and let em burn.
Also making a jum,p out of it would be best
Old Dec 31, 2000 | 07:28 PM
quad040's Avatar
go around them!!!!!!!!!!!!!!!!!!
Old Jan 3, 2001 | 02:59 PM
BANMAN's Avatar
T.N.T.
Old Jan 3, 2001 | 06:04 PM
lonestarbanshee's Avatar
A real pain the the butt ah? All of these ideas are good, I would try soaking it in gas 1st, then try to pull it up.. then screw it.. go around, or make it a jump.. It took a bull dozer to get some of our stumps out. LaTeR
Old Jan 3, 2001 | 07:12 PM
Mike Frey's Avatar
You've got to be kidding me! Manually removing stumps really isn't that much work, especially with three people. Just get a shovel and axe, dig around the base of the stump and start wacking.
Old Jan 3, 2001 | 09:05 PM
jeepin's Avatar
I removed 4 in the last 2 days.I dug 2 of them out yesterday and pulled 2 of them out today.I used a 10 ton hand hoist thing and a nylon strap and a 20 foot chain.The big tree i pulled out was a cedar I am not sure of what kind the other's where.I used the 300ex to pull them out of the way.My cousin's buddy owns a tree service and he rides his 400ex at my house sometimes.He used a stump grinder to get the stumps out at my cousin's mx track and they even made whoops with it.He said he would remove some stumps frre of charge maybe I can swindle him into helping me out!
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
Yamadude1031
Where to Ride
Jul 16, 2015 02:13 PM
