LRD ignition
Old Mar 2, 2001 | 04:43 PM
laegers76's Avatar
i have an lrd ignition on my 250r. and on high rpm in 4,5,6 gear it cuts out. i was wondering if any one else has this problem
justin 00laegers\lrd
Old Mar 3, 2001 | 02:32 PM
trx300EXR's Avatar
sounds like a jettin prob to me
Old Mar 3, 2001 | 02:49 PM
laegers76's Avatar
no it not the jetting it electrical
Old Mar 6, 2001 | 03:08 AM
mx400exer's Avatar
Check your woodruff key on your fly wheel first. Mine was sheared off, causing that type of problem.
Old Mar 6, 2001 | 12:13 PM
PaRoostR's Avatar
Also make shure that you do not have any lose wire connections. If you can not find any and if you have the stock ignition try using it and see if it will work ok then. And your engine does not care (or know) what gear it is in (other than a harder load on it).
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
