yfz450 vs rappy700vs???
i am asking which do you think will be best?
trail wise and speed wise?
I DO NOT OWN EITHER
so what to you guys think?[img]i/expressions/face-icon-small-happy.gif[/img]
im new to sport atvs so
would holeshot tires be the best?
also wat does
hmf pipe increase?
wat do better pistons? do
and compare those two to any other sport quads
I DO NOT OWN EITHER
also wat does
hmf pipe increase?
Holeshot tires are great, but others are comparable. ITP gives you a lot of choices so you can purchase a tire that suits your needs well. HMF pipes give you a healthy gain across the powerband. At least for the YFZ they don't have any real dropoffs at any one point. I run one, it is quality through and through. If you are buying new, I probably wouldn't go for a piston right away. Higher compression gives you some power increase, especially in the lower rpm torque range. Both of those quads wake up pretty good with a new pipe and intake mods, the piston could wait a season or two until you need more power. That way, while the engine is torn apart anyway, you can get some head/valve/porting work done at the same time. Heck, you may even be ready for a big bore kit at that point.
<div class="FTQUOTE"><begin quote>Originally posted by: DODGE57HEMI
I'm having a hard time w/ what you ar asking. Do you own one of these quads? If so then we can give more specifics on it. If not please explain!</end quote></div>
+1
+1
Sep 23, 2015 06:23 AM
